DaHu_285096
10 likes received 250 replies posted 100 replies posted
        Hi, Does anyone know of a site that offers third party components for PSOC. I am looking for a 1-wire component for 5LP. Thanks
odissey1
Level 9
Level 9
Here is PSoC5LP project and associated component to read DS18B20. I recommend to use newest DS18B20 instead of older DS18S20. It is has 12 bit precision right out of the box and cheaper (on DigiKey).
      The component is software based and closely follows previous projects of <pavloven> (a little clean-up and packaged into component for educational purposes mainly). The component reads single DS18B20, but it can be extended for more sensors (on my todo list).
Bob_Marlowe
Level 10
Level 10
Did you already try to enter "one wire" into the Keyword Search-field on top of this page ?
Bob
DaHu_285096
Thank Bob
I can see references to writing 1 wire code and only 1 reference to 1 wire compoenent version 1.1 datasheet but I cannot find the component?
As per my post, I am specifically loooking for a component. Early documents I have read mention the component but I cannot find it.
The second half of myt question was relating to third party components available for PSOC, do you know of any?
ETRO_SSN583
Level 9
Level 9
Did you see this bit banger approach ?
www.spider-e.com/wp/
Reagrads, Dana.
DaHu_285096
Thanks Dana,
I presume from the responses that there is not a 1 wire component available afterall, and further that there is not sir eoffering 3rd party components.
DaHu_285096
 While I am talking about components, I suppose there is not an EM File type component for FRAM ?
ETRO_SSN583
Level 9
Level 9
The emfile component is a composite of Cypress and Segger, and looking
at Segger side (and Cypress) no mention of FRAM support.
You could always file a CASE and see if its being worked on.
To create a technical or issue case at Cypress -
www.cypress.com
“Support”
“Technical Support”
“Create a Case”
You have to be registered on Cypress web site first.
Regards, Dana.
odissey1
Level 9
Level 9
What device are you trying to communicate? if you are looking for 1Wire connection to Maxim's digital temperature sensor DS18B20, I can post a project with custom component.
odissey1
DaHu_285096
 DS18S20 mainly.
EvPa_264126
Level 7
Level 7
500 replies posted 250 replies posted 100 likes received
Something that has been on this forum:
Reading and Writing 1-Wire (iButton) devices with PSoC 3/5/5LP
one wire library
1 Wire Libriay to PSoC Creator 3.0
My friend has created a hardware component as shown below. I have his email.
odissey1
Level 9
Level 9
odissey1
Level 9
Level 9
This article might be useful:
"Reading 1-Wire iButtons using Cypress PSoC 3 and 5/5LP"
http://www.spider-e.com/wp/?p=234
DaHu_285096
 Thanks for the project.
I also need to read other 1-wire devices so may need to cut out the Dallas Temp specific code (once I understand how components work).
ie. Like I2C. There are device specific protocols but there are components for the I2C lower level stuff.
