I typically use Creator 4.0 and by default *.cywrk and *.cyproj extensions are configured to be opened using Creator 4.0.
I recently installed Creator 4.4, which overrode my default extensions; now clicking the file opens it in Creator 4.4, which is not intended.
Is there any way to assign default extensions to use a specific version of the Creator (4.0) in Win10? I didn't have such issue with Win8.1 machine. So far no luck on Win10 - regular extension assignment using Explorer Options doesn't work.
/odissey1
PSoC Creator & Designer Software
Hi @odissey1
We have observed the same issue at our end when using PSoC Creator 4.1 and 4.2
In case you are willing to upgrade your project to a newer version of PSoC Creator, it is recommended to use PSoC Creator 4.4(the latest version). In case you don't want to update the 4.0 project but you have opened it in creator 4.4 you can simply close the project.
In case you have you want to keep 4.0 as the default PSoC creator path then you can try following the workaround in my first post
Best Regards
Ekta
