Is it possible to have both Creator 3 and Creator 4 on the same computer?   I would like to keep the production version of our firmware at the Creator 3.x level and the beta version at Creator 4.   We just released a new product and in case there is a problem, I need to work with the 3.x version to correct the problem(s).  However, I would like to move the beta version to Creator 4 and test.
Ron
cadi_1014291
Level 6
25 likes received 10 likes received 10 likes given
Level 6
Hi Ron,
Yes, it is possible to have Creator 3 and 4 on the same computer. I have both running on Windows 10 and never had problems.
Carlos
cadi_1014291
Level 6
Level 6
Hi Ron,
Carlos
Hi Carlos,
Could you describe how you did that?
Ron
cadi_1014291
Level 6
Level 6
Hi Ron,
Just install Creator 4 normally, major releases (Creator 3.x, 4.x, 5.x, etc) install in parallel, when Creator 4.1 comes out it will be installed "on top" of Creator 4.0.
Carlos
Hi Carlos,
Thanks I will give that a go.
Ron
