Whenever I try to reset thru Debug/Reset I get a dbg.M0007 error - The run request failed. Encountered error (failed to reacquire the device). This happens whether running or halted.
Resets work reliably in Creator 3.0. Is there some new switch I have to change?
Would you mind to post your complete project so that we all can have a look at all of your settings? To do so, use
Bob
I have currently no access to my lab, but can you please enable the instruction cache under the "System" tab in the .cydwr-file.
Bob
No change. This is not a pressing problem - I can wait until you get a chance to look at it. Thanks.
Me too have exactly the same problem.
The problem is present also with every example project.
The problem is only in 3.1 release
With 3.0 all works correctly.
Thank you for your attention
Fabio Ricci
I also exhibit the same problem. Consider filing
a CASE on this and posting back to the forum what
you find out. In filing a CASE point to the project in
this thread.
To create a technical case at Cypress -
“Support”
“Technical Support”
“Create a Case”
You have to be registered on Cypress web site first.
Regards, Dana.
By the way in the project if A/D is setup to bypass the buffer you will get true
R-R performance. Also if based on Vref internal a more accurate result.
Hey guys,
Any resolution to this? I am getting the same result. Everything works in debug until I try to reset. From that point on the debugger appears to loose target acquisition. I have to stop debugging and start again to get it back. This is a pain I would like to avoid.
Glenn
