JoBa_287526
I have several variations of builds within the same project.  I want to build to a file with a name other than the standard <project>.hex.  Can this be done using the Project Settings menu?  If so, how?
ETRO_SSN583
Level 9
Level 9
In Creator, help, documentation, GCC docs, Linker, there are script commands
that allow you to name the output filename.
Regards, Dana.
ETRO_SSN583
Level 9
Level 9
Regards, Dana.
