See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at CyDesigner.Common.Debugger.CyProgramCode.GetDisassemblyText(Boolean includeSource, Boolean includeCode, Boolean showLineNum, Boolean filerBlankLines)
at CyDesigner.Common.Debugger.CyDisassemblyView.DoUpdate(Boolean refreshTxt)
at CyDesigner.Common.Debugger.CyDisassemblyView..ctor(CyDesignerFramework fmk, CyBackendWrapper backendWrapper, CyBreakpointMenu menu)
at CyDesigner.Common.Debugger.CyInterfaceMgr.OpenDisassemblyWindowCommand(Object sender, CyCommandClickedEventArgs args)
at CyDesigner.Common.Debugger.CyInterfaceMgr.ShowDisassembly(UInt64 address)
at CyDesigner.Common.Debugger.CyInterfaceMgr.HandleDebugStateChanged(Object sender, CyDebugStateEventArgs args)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4069.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
psoc_creator
Assembly Version: 4.4.0.80
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/psoc_creator.exe
System
Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.8.4110.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
cydevicedb
Win32 Version: 4.4.0.80
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cydevicedb.DLL
cycmbase
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cycmbase.DLL
System.Windows.Forms
Win32 Version: 4.8.4042.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.3761.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CyFramework
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/CyFramework.DLL
cygde
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cygde.DLL
CyPrjMgmt
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/CyPrjMgmt.DLL
cys3db
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cys3db.DLL
cygdegfxlib
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cygdegfxlib.DLL
cydebugger
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cydebugger.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
UIFramework.Product6.WinForms
Assembly Version: 16.1.330.0
Win32 Version: 16.1.330.0
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/UIFramework.Product6.WinForms.DLL
UIFramework.Product2.WinForms
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/UIFramework.Product2.WinForms.DLL
UIFramework.Product4.WinForms
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/UIFramework.Product4.WinForms.DLL
UIFramework.Product5.WinForms
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/UIFramework.Product5.WinForms.DLL
CyShared
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/CyShared.DLL
cyautomation
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cyautomation.DLL
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Web.Services
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
jwrf2hio
cydsextensions
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cydsextensions.DLL
cygnuarmshipped
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/import/gnu/arm/cygnuarmshipped.dll
cykeilpk51
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/import/keil/pk51/cykeilpk51.dll
cyeditors
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cyeditors.DLL
UIFramework.Product6.Addons.DotNet.WinForms
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/UIFramework.Product6.Addons.DotNet.WinForms.DLL
cytransport
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cytransport.DLL
cypsocdebugger
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cypsocdebugger.EXE
cygdbdebugger
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cygdbdebugger.DLL
cyarmdebugger
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cyarmdebugger.DLL
cyppdeviceio
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cyppdeviceio.DLL
cywin32deviceio
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cywin32deviceio.DLL
bootloader_host
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/bootloader_host.EXE
cydsfit
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cydsfit.EXE
cyfitter_fm
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cyfitter_fm.EXE
cyfitlib
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cyfitlib.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
ICSharpCode.SharpZipLib
Assembly Version: 0.85.4.369
Win32 Version: 0.85.4.369
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/ICSharpCode.SharpZipLib.DLL
System.Drawing.Design
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
System.Design
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
UIFramework.Product1.WinForms
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/UIFramework.Product1.WinForms.DLL
cyhextool
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cyhextool.EXE
cykeilspawner
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cykeilspawner.EXE
cytunerextensions
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cytunerextensions.DLL
cyclangwrapper
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cyclangwrapper.DLL
PP_Accessor
Assembly Version: 3.24.1.2235
Win32 Version: 3.24.1.2235
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/PP_Accessor.DLL
cyp3fit
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cyp3fit.EXE
PP_COM_Wrapper
Assembly Version: 3.29.1.4659
Win32 Version: 3.29.1.4659
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/Programmer/PP_COM_Wrapper.dll
PP_PC_Wrapper
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/Programmer/PP_PC_Wrapper.dll
ProgrammerLibrary
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/Programmer/ProgrammerLibrary.DLL
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
CyComponentLibrary_3eb8b81cae70cb60fec2daa5c94c8ac773c989f9b1e3833ec0d8afda22bbf0fc
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/psoc/content/CyComponentLibrary/CyComponentLibrary.cylib/CyComponentLibrary.dll
cyprimitives_c21f64386661f9d4b3403701ac7745b777acb90566608e886bf03dcef3c3decb
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/psoc/content/CyPrimitives/CyPrimitives.cylib/CyPrimitives.dll
Application_0e9d92a5d9b4f0382f3bbf3f777aa5b35776d48862ef3f2ccf0b091fe1340e32
CodeBase: file:///C:/Users/Jonathan/AppData/Local/Cypress%20Semiconductor/PSoC%20Creator/4.4/customizer_cache/Application_0e9d92a5d9b4f0382f3bbf3f777aa5b35776d48862ef3f2ccf0b091fe1340e32.dll
iAP2_43e971eda468706942663651de8ab59f26901b5c15276963eb7f2dfe24c37e16
CodeBase: file:///C:/Users/Jonathan/AppData/Local/Cypress%20Semiconductor/PSoC%20Creator/4.4/customizer_cache/iAP2_43e971eda468706942663651de8ab59f26901b5c15276963eb7f2dfe24c37e16.dll
Downloads ( 4.4)_820318375d01d3e0df21b4ace844f68d7c3727f69edab2ef3d3e2b3226b03b61
CodeBase: file:///C:/Users/Jonathan/AppData/Local/Cypress%20Semiconductor/PSoC%20Creator/4.4/customizer_cache/Downloads%20(%204.4)_820318375d01d3e0df21b4ace844f68d7c3727f69edab2ef3d3e2b3226b03b61.dll
cydstoolkit
CodeBase: file:///C:/Program%20Files%20(x86)/Cypress/PSoC%20Creator/4.4/PSoC%20Creator/bin/cydstoolkit.DLL
PSoC Creator & Designer Software
- bug
Hello @JoBr_1593366 ,
Please ensure that you don't have any firewall or visual studio software running in the background. My guess is there is something that could be blocking the gdb/server connection that gets spawned during debug causing the crash to occur.
If the issue still persists, I would suggest reinstalling Creator. It could happen that some internal files may have gotten corrupted due to some reason.
Let me know your observations.
Dheeraj
Dheeraj
