OK, here's my conundrum....
Been working on a design for a year, been through lots of iterations. I wanna start with a clean slate, preserving the pinout and most of the instantiated components. Does anyone have a suggestion short of manually re-entering the pinout and copy-paste between the projects?
Any help is much appreciated!
Thanks!
Scott
You may use the feature of Project -> Copy to MyTemplates
This will not only save the components, code and pinout, but can give you a starting point for similar pcb projects. Re-fining the code making it a bit universal will save you hours of generating new projects
Happy coding
Bob
Happy coding
Bob
can the pins be defined in a ctl file?
This link may be useful-
http://www.cypress.com/forum/psoc-creator-software/control-file-psoc-component
