AnLa_2442386
I'm currently creating some psoc component, where I need to have optional pin. How to do that ?
Antoine
odissey1
Level 9
Level 9
AnLa,
Attached is a project showing Pin Show/Hide. Actual Pin inp is being hidden, instead of removing it entirely. Please notice Pin inp settings (Format Shape).
/odissey1
Len_CONSULTRON
Level 9
Level 9
Antoine,
There is some info in the "Component Author Guide" but it is a bit hit or miss.
Do you know how to import someone else's component.  It is very common for component authors to use other's components as a working example.  For example if you import "cy_dma_v1_70" you can use it to reverse-engineer how to add optional terminal pins and the way to make the pin visible (Visibility Expression) based on a Formal Parameter.
Start there.
Len
odissey1
Level 9
Level 9
AnLa,
/odissey1
AnLa_2442386
@Len_CONSULTRON Thanks for the tips, I have tried to reverse the dma component, but i'm facing to blocking issue where my item need be a "cy_m0s8_dma_v1_0". I try a ton of other things, the LUT component seem to be a better start than DMA. I don't found any documentation about cs interface api, I'm not a C# dev, without documentation it's a bit too difficult (do not really have time).
@odissey1 Awesome, that what I looking for, i had never open "format shape" for pin
Thanks you both
Antoine
