I just started working on making my first PSoC component, and I am a little bit confused about something. I did a schematic of the part, but I'm not sure how to access the hardware that I put in my schematic.
For example, I included five digital output pins in my schematic. How do I access those pins in my API files? When using components in a project you generate the application, and then you can use that components autogenerated API to access the hardware, but when I try to generate an application for the schematic in my component the API files for the pins don't seem to be made?
I've read through the component author guide, but I can't find this information.
I'm sure the answer is super simple, but I just can't think of how to do it!
I am using PSoC Creator 2.2 at the moment.
Thank you!
