jepaz
Level 4
Level 4
25 replies posted 10 replies posted 10 questions asked
I am trying to log some variables to Micrium uCProbe, for this the program requires the compiled ELF file created by Psoc Creator after the last update I get this message on ucProbe
Unable to parse ELF files with formats other than DWARF2/3 if you are using IAR, add the following compiler option: --no_dwarf4
how should I do this on creator?
thanks
Bob_Marlowe
Level 10
Level 10
In Creator -> Project -> Build Settings ->ARM GCC-> Compiler ->Command Line you may enter some custom flags.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
KlausK_81
25 sign-ins 10 questions asked 10 sign-ins
Hello Bob,
what specific custom flags are needed to get it generated  ?
Klaus
KlausK_81
Source:
https://gcc.gnu.org/onlinedocs/gcc/Debugging-Options.html
-gdwarf-version
=>  -gdwarf-3
Klaus
Bob_Marlowe
Level 10
Level 10
Well, your error message says "add the following compiler option: --no_dwarf4", so I would try at first that one...
Bob
the one that worked was -gdwarf-3 did try --no_dwarf4 thank you bob
Bob_Marlowe
Level 10
Level 10
Thank you for keeping us informed!
Bob
