- Email to a Friend
Hi, I'm using PSoC Creator 4.4.
In case it helps I'm targeting PSoC 5LP. And I can compile my project from IDE without any problem.
But I want to integrate my project into a "builder", and thus, I need to compile my project from command line.
What's the best approach to do it? Many thanks!
PSoC Creator & Designer Software
- Email to a Friend
Hello.
I have no experience doing this, but there are command line tools that you can put into a text script to invoke Creator tools.
Look inside the PSoC Creator User Guide for the chapter on "CyPrjMgr Command Line Tool". You'll also want to review "CyHexTool Command Line Tool " and "CyElfTool Command Line Tool", all in the same PSoC Creator User Guide. And, there are examples!
Good luck with your project building.
- Email to a Friend
Hello.
- Email to a Friend
Thanks!
- Email to a Friend
ricardo,
I'm glad came up with a useable solution.
In addition, when you are building the project, the "Output" window pushes the CLI command line that invokes that phase of the build.
Therefore if you copy the "Output" window text and remove the command results, you can extract the actual commands and arguments being used.
You can use this filtered output to create a batch file. With some extra work, you can use local environment variables in place of the long absolute paths.
- Email to a Friend
Thanks Len. Useful info!
