I'm checking out the Creator software for compatibility with Windows 11 AND Windows 10 to make sure that my students will have an easy installation and useage. In general, the students will have either Win 11 or Win 10 on the laptops and I'd like to use a common version for both operating systems.
We currently use Creator 4.2 -- I'm concerned that this version will have issues in Windows 11 (works fine in Win10). We could switch to Creator 4.4 if it works in Win11, and also in Win10.
Let me know your experience - positive or negative.
Hi @SuSc_283911 ,
We always recommend using PSoC Creator 4.4, its our latest software.
As per the release notes you can use the PSoC Creator 4.4 for Windows 10 but Windows 11 is the latest version which has been released after PSoC Creator 4.4, so the same has not been tested on the Windows 11. Ideally it should work.
Thanks and regards
Sobhit
Hi @SuSc_283911 ,
Thanks and regards
Sobhit
