ChaoHaiM_11
5 sign-ins First question asked 10 solutions authored
Dear Sir,
I installed PSoC Creator 4.2 IDE on my new notebook,
Environment:
PSoC Creator  4.2 (4.2.0.641)
Culture: English (United States)
OS Version: Microsoft Windows NT 10.0.17134.0
CLR Version: 4.0.30319.42000
Installed CyInstaller Products:
CMSIS-DAP Driver V17
CySmart 1.3
Peripheral Driver Library 3.0.1
Peripheral Driver Library 3.0.3
Peripheral Driver Library 3.0.4
Peripheral Driver Library 3.1.0
PSoC Programmer 3.27.3
PSoC Creator 4.2
Loading any PSoC6 example project, build/run is normal, but when trying to modify the clock configuration (Design Wide Resources->Clocks) failed.
Likes the picture above, default FLL is 100M, i modified to 50M then clicked "OK" button and close the window, nothing(FLL, Clk_HF0 etc.) was changed. Re-open this Edit Clock window, the FLL is still 100M. And i found all the options (both Source Clocks page, FLL/PLL page, High Frequency Clocks page, Miscellaneous Clocks page) cannot be modified. Other items in DWS such as Pins, Interrupts, System etc. are normal!
I have tried to re-install the Creator tool several times, but the problem was the same.
ChaoHaiM_11
Re-installed the OS system. The issue is fixed.
Thanks all.
Roy_Liu
First comment on blog 1000 replies posted 500 solutions authored
This is strange, I guess nobody have been suffering this issue. Are you installed Creator at the default folder - C:\Program Files (x86)\Cypress\PSoC Creator?
Also, check if prerequisites softwares are installed on your PC:
Roy Liu
Roy,
Yes, default folder. I actually installed it normally on another notebook; the same way, but failed on this one.
Roy_Liu
If the prerequisites softwares are installed too. Need to check with Cypress software team.
Roy Liu
ChaoHaiM_11
Thanks all.
SaraLeslie
250 sign-ins 100 sign-ins 50 likes received
We are so glad the community helped solve this problem! Please take a moment to log back in and mark helpful/correct answers to reward other members who helped you. Best Regards, Sara
