Hello
I run Win 8.1
I want to use PSoC Creator 3.3. The problem is during installation, i got an error while installing "PSoCProgrammerSetup" : it says Runtime Error Program : ....\PSoCProgrammerSetup.exe Abnormal program termination
(see image attached)
I tried with version 3.1, same problem. Tried using admin launch as well.
Does anybody has any clue on how to fix this ? Thanks !
I would suggest you to create a support case to get help from Cypress directly. To do so, at top of this page click on "Design Support -> Create a Support Case"
Bob
Ok, thanks, done that !
