I am trying to control a digital multiplexer based on input from a serial command. I can't figure out how to command the multiplexer selection through the software (main.c). How do I do that? What document should I be looking at to determine this?
ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
In Creator a HW mux can be controlled thru use of a control register. Just place the
HW mux and Control register, and look at the datasheets, they contain the APIs to
control it thru simple C calls.
Regards, Dana.
 Many thanks. Looks like its working.
at the moment I try to control the digital multiplexer with register, too. But I have problems to connect them together via wire like Dana. My errors: Multiple drivers on Signal and terminal mux with width 2 is connected to wire with width 1.
I think its not a big problem but sorry I cannot find my mistake!
Flo
I solved my problem with this link: http://www.cypress.com/?rID=40097.
Flo
