This is my first project. I selected pins bugger (ports P5(3) and P5(2) but debugger says "no device detected" Other solution is close application that uses port
1: You need to check whether the chip is in mass storage programmer mode.
2: If not, you can give me your PSoC Programmer configure screenshot:
Bob_Marlowe
Level 10
Level 10
P5(3) is connected to an LED, what do you mean with "Bugger"?
Can it be that your device is in the wrong mode? Try to press the reset button and hold it for > 10s.
Bob
Bob,
Sorry, Bugger was a mistype. This is my first attempt at this 046 kit.
I'm trying to follow document AN79953 Getting Started with PSoC4. I'm in
Part 2 Program the Device. The problem is when I select Debug> Select Debug
Target. The Select Debug Target box opens, but it states: "Port Acquire
Failed. No device detected". The "Possible solutions" are 1. Check cable
connections. and 2. Close any application that uses the port such as PSoC
Programmer.
I know the cable is connected ok the lights are on and sounds are played.
But I don't know how to solve #2 close applications that use the port. I
don't think any apps are using the port.
Steve
On Mon, Sep 17, 2018 at 6:07 AM, bob.marlowe <community-manager@cypress.com>
Bob,
Any ideas on my problem?
Bob,
Programmer.
Steve
On Tue, Sep 18, 2018 at 11:10 PM, Steven Hart <stevehart4620@gmail.com>
The states:  "Port Acquire Failed. No device detected".   The "Possible solutions" are 1. Check cable connections. and 2. Close any application that uses the port such as PSoC Programmer.
The states only a reminder to let you pay attention to the two points.
If you only open a project in creator, ignore the 2#.
You can attached the programmer screenshot.
what do you mean I can "attached programmer screenshot
I'm not sure how to determine if chip is in mass storage programmer mode.
But I did press the SW1 to reset the mode. I then did a build ok, but the
port acquire fails. Attached is a screenshot of PSoC Programmer.
You can find your PC device, if it is in mass storage, it will display.pastedImage_0.png
