hudac_2896761
I would like to use a proximity detector, the application I'm looking for is:
When I put my finger close to a sensor , the sensor detect it.
the issue is that I need: while I keep my finger close to the sensor (1-6 minutes), the sensor still detect that and not calibrate itself and toggle the output.
The interface must be GPO and not I2C...!
Does CY8CMBR3102-SX1I apply my need?
Roy_Liu
First comment on blog 1000 replies posted 500 solutions authored
You may consider to use PSoC4 device, with which you can customize your application(prox detection reaction behaviors)  flexibly.
MBR3 device is not that flexible.
Roy Liu
Roy_Liu
Roy Liu
