I just installed PSoC Creator 3.3 SP1. When I try to create a new project, starting from scratch, CY8CKIT-049-42xx is not part of the target hardware list. I only get several CYBLE modules. A configuration problem?
Beware: I'm a newbie...
Pascal
Bob_Marlowe
Level 10
Level 10
The CY8CKIT-049 is a board, not a chip. You may (if you haven't already) install the kit files. Then you'll find on the start page example projects for your kit.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
Bob,
Thanks for your answer. My question was more about the New project wizard. After latest PSoC Creator installation I performed, CY8CKIT-049-42xx is not present in the list of targets:
[here, I embedded a screenshot, but didn't find a way to make it visible. I'm a newbie for the forum as well 🙂 So I added it as an attached file as well.]
It was listed after an installation I performed on another PC... So, I'm wondering why there is such a difference. Could be that my latest install relies on 3.3 SP1?
Pascal
rola_264706
Level 8
Level 8
        Pascal: you need to install each one of the kits so they appear in Psoc Creator under example projects on the start page. When I am writing a program for the CY8CKIT -049-42xx I just select the 4200 family from the list.
Bob_Marlowe
Level 10
Level 10
In the New Project dialog you are presented all your installed kits only. An installation on another PC does not install your kit files and examples. Try to install from this website the Kit file.
Embedded pictures doesn't work, but attaching does.
Bob
Bob
bobgoar, Bob: got it. I installed the kit files, and now everything's OK. Thanks a lot!
Pascal.
rola_264706
Level 8
Level 8
Pascal: One more thing you need to check the schematic to insure that the pins don't have capacitors and other device in the design.  You can find the schematic's in your windows dir C:/programsx86/Cypress/CY8CKIT-049-42XX/hardware.
