Jun 29, 2013
01:25 PM
Jun 29, 2013
01:25 PM
In the kit the CY8C28 processor module uses a CY8C28000, however this note in the
datasheet may explain why one cannot select this part from Designer 5.4 catalog and
program it. The part is not in Designer part catalog !
56-Pin Part Pinout
The 56-pin SSOP part is for the CY8C28000 On-Chip Debug (OCD) PSoC device.
NoteThis part is only used for in-circuit debugging. It is NOT available for production.
Regards, Dana.
05:13 AM
Jun 30, 2013
05:13 AM
I found a reference on web that the CY8C28000 is a subset of the
CY8C28243-PVXI, and was able to program on a CY8CKIT-001 using
Miniprog 3.
Docs should be updated in -001 kit ?
Regards, Dana.
