May 21, 2013
04:45 PM
May 21, 2013
04:45 PM
A couple of issues that need addressing -
1) Global properties, the OpAmp Bias and Ananlog Buffer properties both were set to low power,
so sine wave distorted. Those should be set to high power.
2) Because the A Buffer is not R-R, its exacerbates the distortion of the DAC output when close to either
rail. Maybe a note should be added to ap note covering this.
3) As an exercise, to eliminate the distortion in 2), I added a PGA, set its G < 1, to get waveform away
from rails, and woulnd up with a highly distorted waveform, ? Not sure why.
Note A Buffer was only loaded with 10M scope probe in all observations, maybe in case of 2) high load
might actually improve output distortion.....?
PSOC Designer 5.4
Regards, Dana.
