I have a problem with the CAN component (PSOC5LP), namely it does not communicate on the 500Kb rate. Having 125kb and normal clock set in "Clocks" it works, and the CAN hardware component datasheet says that it supports speeds up to 1Mb.
I was using AN52701 example project CAN RTR Node1 modified to send a message every 1 second. But it just does not work. Any ideas what the problem could be?
Below you can take a look at Clock settings for 500Kb rate.
The problem occured because I did not had an External Oscillator hardware component connected to the PSoC5 pins. I taught PSoC5 LP already has one, but it only provides support for it.
