Hi guys,
There is a component named ByteSwap in the project of Music_Creation(an example project included in CY8CKIT-033A).But i can not open the datasheet of it in the component configration(attached is the detail).So how can i get it?
AnkitaS_51
ByteSwap is a custom component  .Inside the file "Byte_Swap_Component.cylib" (Byte_Swap_Component.cylib\ByteSwap_v1_10\API)you can find the associated .h and .c file.We dont have the datasheet for this custom component currently
AnkitaS_51
Hi ANKS,
thanks a lot for your reply.
JoBr_1593366
100 sign-ins 50 questions asked 100 replies posted
Also this functionality is built into the I2S component now, isn't it?  Version 2.60 "Added byte swap support for endian compatibility" and "Added dynamic bit resolution control".  Or are there differences between these two features despite having similar names?
AnkitaS_51
Yes,you are right earlier when this project was created ByteSwap functionality was not there in I2S component.
So would it save resources to use the ones built-in to I2S components, or no difference?
