Hello everyone
I've been finishing this proyect that was of other person who worked with me, but I has a problem when I build it
ERROR: .\CortexM0\ARM_GCC_493\Debug\Tarjeta de comunicacion PLC.elf section `.rodata' will not fit in region `rom'
ERROR: section .cyloadablemeta loaded at [00007fc0,00007fff] overlaps section .rodata loaded at [00007ad8,00008147]
ERROR: region `rom' overflowed by 0 bytes
collect2.exe: error: ld returned 1 exit status
The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
If you can give  instruction for how to solve it, i will appreciate it
Here is with the definition error solved
Bob_Marlowe
Level 10
Level 10
The project archive you supplied cannot be opened, sorry.
Use
Try to compile your project with "Release" settings instead of "Debug"
Bob
Sorry for the inconvenience, I attached the Zip already
I have already read about the "Release" but the same error.
Thank you for you help
