ETRO_SSN583
Level 9
Level 9
When users configure analog chains on single supply applications,
confusion often rises as to offsetting and dynamic range and input
common mode range. Same is true of single ended vs differential
applications, like A/D as example.
PSOC designer has one component (may be more), Comparator, that shows
a graphical picture of analog I/O behaviour.
Why not in datasheet config for an analog module show a graphical picture,
for given G and offset and differential settings, show allowed CM range, including,
if applicable, RRIO effects, eg. capable or not capable.
So a basic pic of input range, output swing, for component settings. And show
relationship between input and output, including saturation region.
Regards, Dana.
