I'm working on a project with a CYBLE-416045-02 ...and to put it mildly it's very resource limited: I need almost all the pins for some function.
Now I've tried to auto assign all pins ... and the PSoC Creator fails to find a suitalble digital placement.
The question: If the PSoC Creator does not find a suitable digital placement, does this mean that there IS no suitable placement? In other words: Is the search for a solution for the pin assigment complete / exhaustive?
PSoC Creator & Designer Software
- pin assigment
- psoc
DJour,
Are you willing to share your project on this forum for others to take a look?
This would be the quickest way to address your question.
If you cannot share your project, at least provide the contents of the "Output" window during the Application Build process.
Hi @DJour ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Sidramesh
