Is there any command line interface software for programming CapSense CY8CMBR3 by using Miniprog3 or USB/I2C cable? Thanks.
rola_264706
Level 8
Level 8
        Do you mean a stand alone program? We use psoc Creator to make the program source and use it to program the device or board.. There is a stand alone Cypress programming program also. I am not clear what you want to do.
rola_264706
Level 8
Level 8
I did try Psoc programmer, but seems it does not support CapSense CY8CMBR3.
JobinT_31
25 likes received 10 likes received 5 likes given
Hello Victor,
MBR3 devices are preprogrammed and cannot be re-programmed.
You can configure the MBR3 devices using I2C.
Please refer the design guide: http://www.cypress.com/file/46366/download      [Section '5. Configuring CY8CMBR3xxx']
JOBIN GT
Is there any command line interface software for configuring CapSense CY8CMBR3 by using Miniprog3 or USB/I2C cable? Thanks.
JobinT_31
EZ-Click is the recommended software. Never seen a comand line interface software for this.
http://www.cypress.com/documentation/software-and-drivers/ez-click-20
JOBIN
