May 25, 2021
09:57 AM
May 25, 2021
09:57 AM
Is there a way to add the device name as an argument to a pre-build step? I presume there is a list of variables accessible to pre/post build commands but I can't find it easily....
Could someone point me in the right direction please?
Cheers,
Dan
Labels
PSoC Creator & Designer Software
06:35 AM
May 26, 2021
06:35 AM
Dan,
Would this be helpful?:
The project file xxx.cyprj is an xml file.
If you can parse the xml and look for a string:
"selected_device v=" the string in the xml field is the PsoC device being used in the project.
You can then create a script that parses the .cyprj file places the selected device into your own local environment variable and then use it in your own pre- or post- build executables.
Len
