JoWe_3347861
I want to use an SMIF component to interface to a Quad-SPI SRAM (23LC1024 from Microchip). It seems that all of the pre-loaded .cymem parts are Flash devices.
Can someone help with an example of .cymem settings for a Quad-SPI SRAM part?
John
DheerajK_81
Hello John,
The following code example should be helpful: https://www.cypress.com/documentation/code-examples/ce222967-excelon-ultra-qspi-f-ram-access-using-p...
Note that it doesn't make use of a .cymem file. It has source files which should serve as good reference.
Dheeraj
DheerajK_81
Hello John,
Dheeraj
Thanks Dheeraj,
I'll have a look at the code example.
John
