I am working on psoc 1 based application program of cypress - on pulse oximeter(spo2) AN2313, but constantly facing same issue in pulse error, the probe I am using is a pulse oximeter probe from biometric cable with db9 connector, even tried with red led and ir , photodiode on breadboard circuit, still same problem, does not display spo2 value.
JobinT_31
25 likes received 10 likes received 5 likes given
It seems the pulse oximeter Application Note is obsoleted long back, so please expect limited support for this. I would suggest you to create a technical support case.
Jobin
JobinT_31
Jobin
