alro_2373731
When rotating an AMux component in the software, most of the wires disconnect or switch connections to other wires.  This also happens when increasing the number of channels on the ADC.
Steps to reproduce
  1. Add AMux
  2. Set 4 channels to the component
  3. connect 4 pins
  4. either rotate the component 90 degrees or add a 5th channel.
Also, a bug with your website, please fix the SSL cert for https://origin-www.cypress.com  Its not configured correctly.
Environment:
PSoC Creator  4.1 Update 1 (4.1.0.3210)
Culture: English (United States)
OS Version: Microsoft Windows NT 6.1.7601 Service Pack 1
CLR Version: 4.0.30319.1
Installed CyInstaller Products:
Peripheral Driver Library 2.1.0
PSoC Programmer 3.26.0
Loaded Plugins:
Version: 4.1.0.3210
Company: Cypress Semiconductor
Description: Add a feedback page to the framework
Version: 4.1.0.3210
Description: Loads component customizers.
Name: Addin Discovery
Version: 4.1.0.3210
Description: Discovers PSoC Creator addins (kits, language packs, etc)
Version: 4.1.0.3210
Description: Device Catalog Plugin
Version: 4.1.0.3210
Description: Adds the topics available in the documentation.
Version: 4.1.0.3210
Description: Adds a start page to the framework.
Name: Output Window Plugin
Version: 4.1.0.3210
Description: Adds the output window
Version: 4.1.0.3210
Description: The Source Code Control Manager is the central class used for SCC actions within PSoC Creator.
Name: Symbol, Schematic and SchMacro Factory
Version: 4.1.0.3210
Description: The Symbol and Schematic Factory is used to load, cache, and retrieve symbols and schematics.
Name: Project Manager Plugin
Version: 4.1.0.3210
Description: Adds project management related functionality.
Version: 4.1.0.3210
Description: Loads the Symbol and Schematic editors
Version: 4.1.0.3210
Description: Supports user files in multiple languages
Version: 4.1.0.3210
Description: The Workspace Factory is used to retrieve instances of PSoC Creator workspaces.
Version: 4.1.0.3210
Description: The Project Factory is used to retrieve instances of PSoC Creator projects.
Version: 4.1.0.3210
Description: PSoC Creator Toolchain Manager
Name: ARM GCC Generic
Version: 4.1.0.3210
Description: ARM GNU Generic
Name: ARM MDK Generic
Version: 4.1.0.3210
Description: ARM MDK Generic
Name: ARM IAR Generic
Version: 4.1.0.3210
Description: ARM IAR Generic
Name: DP8051 Keil Generic
Version: 4.1.0.3210
Description: DP8051 Keil Generic
Version: 4.1.0.3210
Description: Adds a dialog that allows the user to select a device.
Name: File Editor Factory Plugin
Version: 4.1.0.3210
Description: Add file editors to the framework.
Name: Transport Framework
Version: 4.1.0.3210
Description: Provides a generic device communication framework for use by other plugins.
Version: 4.1.0.3210
Description: The Core Debugger provides an architecture independent framework for the common debug features.
Version: 4.1.0.3210
Description: Provides debugging support for the different PSoC families through a GDB back end.
Version: 4.1.0.3210
Description: Provides debugging support for FM device families
Name: Device IO Transport
Version: 4.1.0.3210
Description: Provides device IO support for Cypress devices though PSoC Programmer APIs.
Name: Serial Transport
Version: 4.1.0.3210
Description: Provides basic serial device support for the rest of the tool.
Version: 4.1.0.3210
Description: Provides a host tool to perform bootloading operations.
Name: Background Elaborator
Version: 4.1.0.3210
Description: PSoC Creator Background Elaborator.
Version: 4.1.0.3210
Description: The TypeCache Factory is used to retrieve instances of TypeCaches.
Version: 4.1.0.3210
Description: PSoC Fitter Plugin
Version: 4.1.0.3210
Description: FM Fitter Plugin
Version: 4.1.0.3210
Description: Registers resource editors with devices.
Version: 4.1.0.3210
Description: Enables quick and correct development of applications that use DMA.
Version: 4.1.0.3210
Description: Manages custom component tuner executables
Version: 4.1.0.3210
Description: The Notice Window displays notices (status messages / errors with managed lifetimes).
JobinT_31
25 likes received 10 likes received 5 likes given
Hello Alex,
The rubber banding feature is not implemented for shape-> rotate or any component changes. We had created an enhancement request to PSoC Creator software team [internal ticket number - 294501]
Jobin GT
AnkitaS_51
Can you please provide screenshots of the error. I tried the steps mentioned with AMuxHw_v1_50 componenet in Creator4.1 Update1 .But was unable to recreate the issue.
JobinT_31
Hello Alex,
Jobin GT
