5 servo and 5 Potentiometre by Two Psoc 5lp
How to controle 5 servo (9g) by ADC (input from potentiometre)  from 0 To180°
thank you
secound step ; how to use uart to sent 'analog input' to an other  Psoc to controle the same 5 servo
Bob_Marlowe
Level 10
Level 10
The specs for your servo are:
Pulsewidth = 1ms -> Leftmost position
Pulse width = 2 ms -> Rightmost position
Repitition rate 20ms / 50 Hz
So what you need is a PWM component configured to a period of 20ms. By setting the compare value accordingly you will be able to control the servo position at your need.
Example:
Input clock 1MHz
16 bit wide PWM USB type. One output
Period value 19999
Compare value 999 to 1999
You will need a function that converts your ADC result to the required compare - value (ADC * Gain + 999)
"secound step ; how to use uart to sent 'analog input' to an other  Psoc to controle the same 5 servo "
You will have to design a communication protocol. This fixes
What is sent
Who may send
What is the response (good / bad)
best could be to define a structure of the data to be send which contaoins a lead-in (starter byte) and a lead-out (end byte) which allows for synchronization of the input stream. Both of your PSoCs may not be switched on at the same time or when a byte was lost this feature will be very helpful.
Bob
Bob_Marlowe
Level 10
Level 10
Example:
Input clock 1MHz
Period value 19999
What is sent
Who may send
Bob
fist step working  now sir
but from 0 to 90° LOL crazy time i think for me
thank you so much for ur help
can u help me how to creat a protocol uart? about what i  say befor....
look to my first progrme sir using one servo and one potentiometre
Bob_Marlowe
Level 10
Level 10
When you want to use sprintf() you need to
set the heap size to 0x0200 (in System view)
enable newlib nano float formatting (in Project-> Build settings->Linker)
Bob
        Im not sure if i want to use sprintf() Coz really i dont know the good way to do that.. exactly to sent data "angle of evry servo"...by uart.... Just all i want is how to creat a protocol.. how to sent data... In psoc ... coz with "arduino i creat a protocol for the dsame project.. with two arduino uno card and it working... Thnks again Ms Bob
