PSoC™ Creator & Designer
RobynW_26
In the attached zip file, you'll find a single library contraining 20 simple teaching components.  These components and their associated datasheets run through a number of examples with information on how to build these simple engineering concepts into a Component.
  1. CYCC_CY42    BCD to Decimal Decoder (1-of-10)
  2.
  3. CYCC_CY74    D-Type Flip-Flop with Set and Reset
  4.
  5. CYCC_CY112   JK Flip-Flop with Set and Reset
  6.
  7. CYCC_CY161   8-bit Binary Counter: Asynchronous Reset
  8.
  9. CYCC_CY163   8-bit Binary Counter: Synchronous Reset
  10.
  11. CYCC_CY164   8-bit Serial-In/Parallel-Out Shift Register
  12.
  13. CYCC_CY166   8-bit Parallel-In/Serial-Out Shift Register
  14.
  15. CYCC_CY182   Look-Ahead Carry Generator
  16.
  17. CYCC_CY191   8-bit Binary Up/Down Counter
  18.
  19. CYCC_CY194   8-bit Bidirectional Universal Shift Register
  20.
  21. CYCC_CY195   8-bit Parallel Access Shift Register
  22.
  23. CYCC_CY273   Octal D-Type Flip-Flop with Reset
  24.
  25. CYCC_CY273T  Octal T-Type Flip-Flop with Reset
  26.
  27. CYCC_CY293A  8-bit Accumulator with Carry In and Out
  28.
  29. CYCC_CYDSMod  Delta Sigma Modulated Density Generator
  30.
  31. CYCC_DSModA  Delta Sigma Modulated Density Generator with Dither
  32.
  33. CYCC_PRMod   Pseudo Random Modulated Density Generator
  34.
  35. CYCC_PWM8   Pulse Width Modulator with Enable
  36.
  37. CYCC_PWMod   Pulse Width Modulated Density Generator
  38.
  39. CYCC_PWModA  Pulse Width Modulated Density Generator with Dither
  40.
Design the way you think with PSoC Creator!
ViDv_264506
Contributor II
a. Many thanks for these very usefull components.
b. Nice motivation to learn Verilog for PSoC.
c. Please, can you be so kind and enlarge the collection for 74HC165, 74HC390, 74HC393, and 74HC4094 components.
Viktor
HeLi_263931
Honored Contributor II
Is there a reason you need 4bit ripple counters when there is already the basic counter component available (which implements a synchronous counter)?
And when you want to learn verilog, e.g. the HC165 is nearly the same as the provided HC166, so you might want to implement this by qourself...
ETRO_SSN583
Esteemed Contributor
Some training resources -
www.cypress.com/      Just Enough Verilog for PSoC® - KBA86336
www.cypress.com/       Creating a Verilog-based Component - KBA86338
www.cypress.com/  AN82250 - PSoC® 3, PSoC 4, and PSoC 5LP Implementing Programmable Logic Designs with Verilog
www.cypress.com/   Datapath Videos
www.cypress.com/        PLD Componets using Verilog
Regards, Dana.
 dana you forgot the warp_verilog_reference.pdf file found in PSOC Creator documentation folder.
 Great and usefull components !
Many thanks
Nice to have more learning materials. Good work.
