ram overflow error with coustem linker file
i develop one project on cy8c4246 using psoc creator and trying to move variable to particular location in ram.For that i modified linker after reading some documents.But when i build code its got ram and flash overflow error this is because below line i think in .map file
 *fill*         0x200004c9 0x200004c7
which is un wanted.i don't know how it enter in map file.here i attach my project.
AnkitaS_51
This Application Note properly defines the step needed to place code and variables in custom locations.Please go through page#23 & #29(section9.3 &9.4)- http://www.cypress.com/file/46521/download This is a KBA for placing functions. http://www.cypress.com/knowledge-base-article/locating-object-files-specific-memory-section-psoc-cre... Assuring you of our best support.
AnkitaS_51
i already go through this document and done required setting but i think its not taking my custom generated linker file.
sorry its my fault i think path is not properly set.now its working.is it possible that variable will appear in same order as defined in file?
AnkitaS_51
You can check that via Debugger
