wifi scan issue: failed to connect to github.com
joel_4789771
5 sign-ins Welcome! First solution authored
1/ I am following the "Using the code example" description at https://github.com/Infineon/mtb-example-anycloud-wifi-scan. After selecting the kit -062-4343W , select the Wifi Scan application tick and apply Create, the following message appears:
fatal: unable to access 'https://github.com/cypresssemiconductorco/mtb-example-anycloud-wifi-scan/': Failed to connect to github.com port 443 after 1083 ms: Connection refused.
Could you please tell how to proceed to load the example code and follow this example?.
2/ I have also accessed to:
https://github.com/cypresssemiconductorco/mtb-example-anycloud-wifi-scan/ and download the ZIP code, but then I do not know how to load the project on MODUS Tool BOX  with the unzipped folders. If this way is a solution to the  github access defined on 1/, please let me know how to proceed.
Thanks in advance.
Murali_R
250 sign-ins 250 replies posted 100 solutions authored
You can set up a proxy or use a offline content as mentioned here https://www.infineon.com/dgdl/Infineon-ModusToolbox_Project_Creator_Guide_(Version_1.2.0)-Software-v...
This blog should also help you out https://community.infineon.com/t5/Knowledge-Base-Articles/Using-ModusToolbox-Software-Behind-a-Firew...
Or else you can check out the code from github and import it onto MTB.
Murali_R
