where is the memory configuration file for my Nor Flash
victor2022
10 questions asked 5 replies posted 10 sign-ins
Hi, Friend
    I am using Nor Flash of W25N01GWZEIG, unfortunately, it is not in the list of QSPI configurator. Do you know where is its memory configuration file or I can choose another model number to proceed. BTW, use auto detect does not work. Thanks in advance.
Victor
Ida_Wang
100 replies posted 25 solutions authored 10 likes received
Hi @victor2022 , you can find configuration file in the path "..\ModusToolbox\tools_3.1\qspi-configurator\data\memory" . If you want to use a new device, provide the .cymem file, and put it in the configuration path, then you can find the device from the QSPI configurator.
Ida_Wang
