hi,
is there a guide how to build a project utilizing UDB's with modus.
i.e. it's ok to use psoc creator to build/synthesize the verilog file "once", then include it in the make script in modus
PSoC 6 MCU
Hi @DaEr_349131,
The UDBs are not supported by the ModusToolbox. However, there is a tool created by one of the forum contributors that can be used to port the UDB Components created in the PSoC creator to ModusToolbox. You can refer to this thread “How do I create a custom UDB solution in the Modus toolbox?”
Please, let us know if any further clarification is required.
Thank you
Best Regards
Raj Chaudhari
Hi @DaEr_349131,
Thank you
Best Regards
Raj Chaudhari
