Amar_Hiremath
25 sign-ins 10 questions asked 25 replies posted
is it possible to read/write the usb using psoc6.
Ekta
750 replies posted First like given 250 solutions authored
Hi @Amar_Hiremath
Could you please provide moe information on your requirements?
Do you want to use PSoC USB in Host mode or Device mode?
PSoC 6 supports both Host and device configuration for PSoC 6. Below are two code examples for USB host and USB  device data transfer when using CDC class:
https://github.com/Infineon/mtb-example-usb-host-cdc-echo
https://github.com/Infineon/mtb-example-usb-device-cdc-echo
Hope this helps.
Best Regards
Ekta
Ekta
Hi @Amar_Hiremath
Hope this helps.
Best Regards
Ekta
