Tim_Shih
250 sign-ins 50 replies posted 50 questions asked
Dear Receiver,
I'm learning PSOC 6 recently.
I found almost all sample codes are based on M4 only.
Do you have example codes only based on M0 + ?!
I would like to know how to design M0+ only.
Thank you so much.
RodolfoGL
250 solutions authored 250 sign-ins 5 comments on KBA
RodolfoGL
We have only a few examples using CM0+. Any code example with "dual-cpu" in the name uses the CM0+.
https://github.com/infineon?q=psoc6-dual-cpu&type=all&language=&sort=
I recommend to look at these two:
https://github.com/Infineon/mtb-example-psoc6-dual-cpu-ipc-pipes
https://github.com/Infineon/mtb-example-psoc6-dual-cpu-ipc-sema
