Hi
I am using CY8CPROTO-062-4343W board I downloaded Wi-Fi scan program in ModusToolbox ide .While tracing the code in UART it showing like below. How can I sort out this issue
Hi @suryasundar96 :
Have you modified any code based on the code example?
If not, please change another hardware for cross testing.
This error happened when initializing WiFi hardware.
Normally, you don't need to change anything, and you can get the log like below after programming:
CE230270 - Wi-Fi Scan
WLAN MAC Address : 00:9D:6B:64:C2:DB
WLAN Firmware : wl0: Jul 18 2021 19:15:39 version 7.45.98.120 (56df937 CY) FWID 01-69db62cf
WLAN CLM : API: 12.2 Data: 9.10.39 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2021-07-18 19:03:20
WHD VERSION : v2.5.0 : v2.5.0 : GCC 10.3 : 2022-09-23 13:14:02 +0800
Info: Scanning without any filter
# SSID RSSI Channel MAC Address Security
1 TP-LINK_515B5A -88 6 14:E6:E4:51:5B:5A WPA2-MIXED-PSK
2 DIRECT-xy20F11F- -85 6 0E:61:27:20:F1:1F WPA2-AES-PSK
3 c-test -31 11 A0:63:91:D3:0C:29 WPA2-AES-PSK
Colin
Hi @suryasundar96 :
Colin
