SURYASUNDAR
First like given 50 sign-ins First solution authored
I am using CYBLE-343072-02 module as mesh node and  PSoC™ 6 Wi-Fi BT Prototyping Kit  as a gate way. Mesh part got completed successfully but I cannot able to configure the  PSoC™  board with  MESH board through Bluetooth and i need to send data to server through WIFI .How we can integrate that?. What are the steps we need to take for that.
BragadeeshV
BragadeeshV
Hi @SURYASUNDAR ,
Could you please clarify what is the role of the PSoC 6 + 4343W kit in the BLE mesh? Please share a block diagram of your requirement to help you better.
Bragadeesh
PSoC6 that we are using as a gateway to send datas from the ble nodes to
the server through WIFI .Here i am attaching the block diagram of planning
BragadeeshV
Hi @SURYASUNDAR ,
Please check the following example
https://github.com/Infineon/mtb-example-anycloud-ble-wifi-gateway
Bragadeesh
