PSoC™ 6 Forum Discussions
SURYASUNDAR
First solution authored 25 sign-ins 5 replies posted
I am using CYBLE-343072-02 module as mesh node and  PSoC™ 6 Wi-Fi BT Prototyping Kit  as a gate way. Mesh part got completed successfully but I cannot able to configure the  PSoC™  board with  MESH board through Bluetooth and i need to send data to server through WIFI .How we can integrate that?. What are the steps we need to take for that.
BragadeeshV
Moderator First question asked 1000 replies posted 750 replies posted
BragadeeshV
Hi @SURYASUNDAR ,
Could you please clarify what is the role of the PSoC 6 + 4343W kit in the BLE mesh? Please share a block diagram of your requirement to help you better.
Bragadeesh
SURYASUNDAR
PSoC6 that we are using as a gateway to send datas from the ble nodes to
the server through WIFI .Here i am attaching the block diagram of planning
BragadeeshV
Hi @SURYASUNDAR ,
Please check the following example
https://github.com/Infineon/mtb-example-anycloud-ble-wifi-gateway
Bragadeesh
