I have a requirement to clock 3 counters from within the PSoC at 27MHz. i want to time the difference between 3 external events.
the smallest difference is 37ns, with the whole process being completed within 7us.
i don't need to process any of this data until completion.
ideally i'd like to be in deep sleep but the wake up transition looks like it will take too long. in low power active (just on the M4 core) what clock can i use to generate the 27MHz, and what would the current consumption be during this process?
thanks
graham
Hello Graham,
You can use any of the clocks mentioned above in the table (LPACTIVE mode).
In the LPACTIVE/LPSLEEP modes, the maximum device current should not exceed 25 mA (refer to the datasheet for min/max numbers). Firmware should
enable/disable blocks and reduce the clock frequencies appropriately to ensure power consumption does not exceed the limit.
If you have any doubts please feel free to ping a message here.
Yeshwanth
Hello Graham,
Yeshwanth
Thanks Yeshwanth
Is there a power calculator that i can use to estimate the active current consumption?
thanks again
graham
As far as I know, there are no power calculators. You can measure the current by connecting an ammeter to the J8 header on the PSoC 6 development board.
For power reduction you can turn off clocks which are not required.
Yeshwanth
