- Email to a Friend
I have built the attached circuit which includes 2 resistors, op amp, ADC and 3 analogue pins. It keeps giving me error and I am not sure why. I have attached the project for your reference.
The error:
'Pin guidance unavailable: Opamp \Opamp_1:cy_mxs40_opamp\ must be configured for Output to pin'
'Opamp \Opamp_1:cy_mxs40_opamp\ must be configured for Output to pin'
Thank you,
- Email to a Friend
You have configured "Internal Only" for "Output Drive" in the configuration of the Opamp_1 component.
If you want to output to an external pin, you should specify "Output to pin".
I would like to add that if P8[0]/P8[1]/P8[2] are assigned to OpAmp_1 pins, analog routing is not possible.
Assigning P9[0]/P9[1]/P9[2] did not cause an error.
Shima
- Email to a Friend
Shima
- Email to a Friend
Its working, thank you so much!
