hello.
After setting up USB CDC (using USB configurator), a modus build error occurs.
There was no error before setting USC CDC, and the example (USB_CDC_echo) was used for setting.
I attach the usb configuration file and modus project.
There are several parts that need to be corrected, but first, I would like to ask why this is the case.
thank you.
Hi @air,
Can you please let us know the error that you are getting? A screenshot of the error will help! Also, can you please let us know the device that you are using?
Rakshith M B
I use CY8C6136FDI-F42.
Below is build message.
thanks.
08:16:52 **** Incremental Build of configuration Debug for project freeTROS_6136 ****
"C:\\Infineon\\Tools\\ModusToolbox\\tools_2.4\\modus-shell\\bin\\make" CY_MAKE_IDE=eclipse CY_MAKE_IDE_VERSION=2.4 CY_IDE_TOOLS_DIR=C:/Infineon/Tools/ModusToolbox/tools_2.4 -j12 all
Tools Directory: C:/Infineon/Tools/ModusToolbox/tools_2.4
custom_6136.mk: ./TARGET_custom_6136/custom_6136.mk
Running device-configurator to update stale files...
Log file= "C:/Users/user/AppData/Local/Temp/device-configurator-cli/device-configurator-cli-20220726.081657.065-9672.log"
Command line= "C:/Infineon/Tools/ModusToolbox/tools_2.4/device-configurator/device-configurator-cli.exe --library ../mtb_shared/mtb-pdl-cat1/release-v2.3.1/devicesupport.xml --build ./TARGET_custom_6136/COMPONENT_BSP_DESIGN_MODUS/design.modus --check-mcu=CY8C6136FDI-F42 --check-coprocessors= --readonly"
ERROR: Generating code failed. Code generation errors:
- Errors exist in the project's configuration:
The connection list for signal "Ch4 Vplus" can't be empty
make: *** [../mtb_shared/core-make/release-v1.9.0/make/core/config.mk:259: TARGET_custom_6136/COMPONENT_BSP_DESIGN_MODUS/GeneratedSource/cycfg.timestamp] Error 1
"C:/Infineon/Tools/ModusToolbox/tools_2.4/modus-shell/bin/make CY_MAKE_IDE=eclipse CY_MAKE_IDE_VERSION=2.4 CY_IDE_TOOLS_DIR=C:/Infineon/Tools/ModusToolbox/tools_2.4 -j12 all" terminated with exit code 2. Build might be incomplete.
08:17:00 Build Failed. 1 errors, 0 warnings. (took 7s.861ms)
The error seems to be because ADC_SAR CH4 is not specified.
- One more question,
When I try 7 CH allocation, I get the following error message.
I wonder if there are any restrictions on port usage.
Below is the port setting for the current error.
CH0 : P10.0
CH1 : P10.1
CH2 : P10.4
CH3 : P10.5
CH4 : P5.5
CH5 : P5.6
CH6 : P6.3
