miniProg3 DataBase Upgrade
Justin
First question asked Welcome!
when I program CY8c6244 with miniProg3 , below message display on PSoc programmer window.
I want to know how to upgrade minoProg3 to support CY8C6244.
Read Finished at 오전 11:10:26 |
| FAILED! PSoC Device (6B A0 24 77) is not in the DataBase
| Detected JTAG ID: "6B A0 24 77" is not in database
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @Justin ,
This particular device CY8C6244 is not supported in PSoC Creator v 4.4 and hence the same is also not supported in PSoC Programmer, which is why you get the above error message.
You can verify if your device is supported by checking for your device part number in "Device Selector" of PSoC Creator as shown below:
But this device , CY8C6244, is supported in ModusToolbox v 2.3 as you can see from the below image:
Can you try building a sample code from ModusToolbox for your device and trying to program your device from the quick panel of ModusToolbox as shown below
NOTE : MiniProg3 is not supported in ModusToolbox but only MiniProg4.
Hope his helps.
AlenAn14
Hi @Justin ,
Hope his helps.
