Manoj_Kumar
50 sign-ins 25 replies posted 10 questions asked
hi, while building the project am getting following error.
make[1]: *** [../mtb_shared/core-make/release-v3.0.3/make/core/build.mk:435: C:/DemoProject/build/CY8C6245LQI/Release/AIController-Psoc6.elf] Error 1
make: *** [../mtb_shared/core-make/release-v3.0.3/make/core/main.mk:376: secondstage_build] Error 2
I tried reinstalling the Modustoolbox, also corrected the path of Environment variable, but nothing seems to be working.
ADSW
250 sign-ins 50 solutions authored 25 likes received
Hello @Manoj_Kumar ,
Which version of MTB are you using ?
and could you also please share the build output where you are observing the errors in ?
you can try to install the latest version of MTB to the path C.
Thanks & regards
Andri
Yes, am able to compile it in debug mode,
But when i try to flash and debug the project am getting the following
 And when am trying to build in Release mode, then am getting the make error.
Manoj_Kumar
@ADSW
i am using Modustoolbox 3.0, when i keep my project in Release, am getting this make error.
I don't want to make use of latest MTB as the libraries may get updated, i want to continue on the same.
ADSW
If you configure the project to debug, can it be compiled ?
Could you please share the build output of the errors ?
and have you tried to re-install MTB 3.0 to the path C:/ ?
Thanks & regards
Andri
MarioSullivan
First reply posted Welcome!
make: *** [../mtb_shared/core-make/release-v3.0.3/make/core/main.mk:376: secondstage_build] Error 2 : https://goldendoodlehub.com/
I have tried reinstalling ModusToolbox and correcting the environment variables, but the issue persists. I've ensured that the CY_TOOLS_PATHS environment variable is correctly set and verified that all necessary libraries are installed using make getlibs. Despite these efforts, the error remains unresolved.
