kit releated issue
atga_4639981
hello sir .i am using the psoc 6 BLE pioneer kit CY8CCKI-062-BLE.i am doing the simply glow  the LED but LED is not glow.i write this code also correct and no error.
please tell me what happen.
regards
gaikwadatul661@gmail.com
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
Open the PSoC Creator IDE, then open the PSoC 63 code example like the below figure:pastedImage_0.png
The code example explains how to control the GPIO.
As you said, your code is right, one more question, do you use the Oscilloscope to test the actual voltage state of the pin you control?
LinglingG_46
