- Email to a Friend
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Build Project 'M4' - Target 'Target 1'
linking...
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(126): warning: L6314W: No section matches pattern *(.cy_app_signature).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(136): warning: L6314W: No section matches pattern *(.cy_em_eeprom).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(145): warning: L6314W: No section matches pattern *(.cy_sflash_user_data).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(154): warning: L6314W: No section matches pattern *(.cy_sflash_nar).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(163): warning: L6314W: No section matches pattern *(.cy_sflash_public_key).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(172): warning: L6314W: No section matches pattern *(.cy_toc_part2).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(181): warning: L6314W: No section matches pattern *(.cy_rtoc_part2).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(191): warning: L6314W: No section matches pattern *(.cy_xip).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(201): warning: L6314W: No section matches pattern *(.cy_efuse).
Program Size: Code=13182 RO-data=2174 RW-data=692 ZI-data=109224
Finished: 0 information, 9 warning and 0 error messages.
FromELF: creating hex file...
After Build - User command #1: C:\Keil_v5\ARM\PACK\Cypress\Pack\2.0.0\Device\CY8C6347BZI-BLD53_Pack\Other\postbuildCortexM4.bat "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\M4.axf" "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\" "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\" "cmsis" "C:\Keil_v5\ARM\PACK\Cypress\Pack\2.0.0\Device\CY8C6347BZI-BLD53_Pack\Other\win\elf"
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>IF /I "cmsis" NEQ "cmsis" GOTO not_cmsis
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>copy /Y "C:\Keil_v5\ARM\PACK\Cypress\Pack\2.0.0\Device\CY8C6347BZI-BLD53_Pack\Other\win\elf\cymcuelftool.exe" "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\\cymcuelftool.exe"
已复制 1 个文件。
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>move /Y "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\M4.axf" "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_link.axf"
移动了 1 个文件。
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>for %i in ("E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\\Objects\*_link.axf") do @(IF "%i" NEQ "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_link.axf" set MergeFiles=!MergeFiles! "%i" )
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>set MergeFiles="E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_signed.axf"
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>"E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\\cymcuelftool.exe" --sign "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_link.axf" --output "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_signed.axf"
No ELF section .cychecksum found, creating one
Application checksum calculated and stored in ELF section .cychecksum
Checksum calculated and stored in ELF section .cymeta
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>"E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\\cymcuelftool.exe" --merge "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_signed.axf" --output "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\M4.axf"
Expected at least 2 elf file arguments for -M/--merge
Usage:
Display help:
cymcuelftool -h/--help
Display version information:
cymcuelftool -v/--version
Display memory allocation by type:
cymcuelftool -A/--allocation file.elf
Merge ELF files:
cymcuelftool -M/--merge complete_app1.elf complete_app2.elf ... [--output merged.elf] [--hex merged.hex]
Sign ELF file, with option for secure (encrypted) signature:
cymcuelftool -S/--sign unsigned.elf [<SignScheme>] [--output signed.elf] [--hex signed.hex]
Generate Patch file:
cymcuelftool -P/--patch file.elf [--encrypt <Cipher*> --key key.txt [--iv iv.txt]] [--output patch.cyacd2]
*NOTE: RSAES-PKCS and RSASSA-PKCS not allowed for this command
Create Code sharing file:
cymcuelftool -R/--codeshare file.elf symbols.txt <GCC/ARMCC/IAR> [--output shared.s]
<SignScheme> is only used for signing the user application. It must be ONE of:
1) HMAC <Hash*> --key key.txt (*CRC not supported)
2) CMAC-AES-XXX* --key key.txt (*XXX can be 128, 192, or 256)
3) <Hash> [--encrypt <Cipher> --key key.txt [--iv iv.txt]]
<Hash>: CRC, SHA1, SHA224, SHA256, SHA384, SHA512
<Cipher> (requires key):
Public-key: RSAES-PKCS, RSASSA-PKCS
Symmetric: DES-ECB, TDES-ECB, AES-{128|192|256}-{ECB|CBC|CFB}
key.txt: ASCII text file containing key appropriate for chosen Cipher. May be symmetric hex key or PEM format for RSA cipher variants
iv.txt: ASCII text file containing initialization vector for certain encryption algorithms
".\ObjectsM4\M4.axf" - 0 Error(s), 9 Warning(s).
Build Time Elapsed: 00:00:02
- Email to a Friend
I think you're using µVision 5, when you exporting, select CMSIS-Pack Projects
- Email to a Friend
Hi Jerry, Could you double-check your project exporting with using PSoC Creator?
PSoC Creator's help file provided good guidance on this exporting. Please do not ignore any steps described in the help menu.
- Email to a Friend
