Hi Cypress:
when we use kitprog3 to programmer pso62 mcu , but it show error as below: please advice it ;
Error Logo:
Open On-Chip Debugger 0.10.0+dev-4.1.0.1058 (2020-08-11-03:47)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
adapter speed: 2000 kHz
adapter srst delay: 25
adapter srst pulse_width: 25
** Auto-acquire enabled, use "set ENABLE_ACQUIRE 0" to disable
cortex_m reset_config sysresetreq
Info : Using CMSIS loader 'CY8C6xxA_SMIF' for bank 'psoc6_smif0_cm0' (footprint 14672 bytes)
Warn : SFlash programming allowed for regions: USER, TOC, KEY
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: FW Version = 2.0.0
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : KitProg3: FW version: 1.21.707
Warn :
* KitProg firmware is out of date, please update to the latest version (2.10.878)
* using fw-loader tool which can be found in the following folder
* C:/Users/a89114/ModusToolbox/tools_2.2/fw-loader
Info : KitProg3: Pipelined transfers enabled
Info : VTarget = 2.834 V
Info : kitprog3: acquiring the device...
Info : clock speed 2000 kHz
Info : SWD DPIDR 0x6ba02477
Error: Failed to write memory at 0xe000ee00
Info : starting gdb server for psoc6.cpu.cm0 on 3333
Info : Listening on port 3333 for gdb connections
Info : starting gdb server for psoc6.cpu.cm4 on 3334
Info : Listening on port 3334 for gdb connections
** Silicon: 0xE455, Family: 0x102, Rev.: 0x12 (A1)
** Detected Device: CY8C624AFNI-S2D43
** Detected Main Flash size, kb: 2048
** Flash Boot version: 3.1.0.378
** Chip Protection: NORMAL
Info : psoc6.cpu.cm4: hardware has 6 breakpoints, 4 watchpoints
Info : AP write error, reset will not halt
in procedure 'program'
Info : psoc6.cpu.cm4: external reset detected
** Program operation failed **
Polling target psoc6.cpu.cm0 failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
srst_only separate srst_gates_jtag srst_open_drain connect_deassert_srst
Error executing event reset-deassert-post on target psoc6.cpu.cm0:
C:/Users/a89114/ModusToolbox/tools_2.2/openocd/bin/../scripts/target/mxs40/mxs40_common.cfg:99: Error:
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 279
in procedure 'mxs40_reset_deassert_post' called at file "C:/Users/a89114/ModusToolbox/tools_2.2/openocd/bin/../scripts/target/mxs40/psoc6_common.cfg", line 128
at file "C:/Users/a89114/ModusToolbox/tools_2.2/openocd/bin/../scripts/target/mxs40/mxs40_common.cfg", line 99
Examination failed, GDB will be halted. Polling again in 300ms
shutdown command invoked
Info : psoc6.dap: powering down debug domain...
I recently had the same issue:
I removed the Kitprog3 and placed a header on it to use as a standalone programmer
– I was using ( PSoC 6 BLE Prototyping Kit (CY8CPROTO-063-BLE).
KitProg3 - SWD lines -
I was able to program cypress DVK on the other end of with the KitProg3 , but when I tried to program a external board using a different device it would not even see the silicon ID.
Solution that worked for me:
I see from your message your programmer is at:
In the message it is asking you to upgrade : to a newer version
Note: My KitProg3 was at an older firmware version too .
I updated my KitProg3 to the latest firmware version – and then was able to program my external device.
I’m not sure what changed from - KitProg3: FW version: 1.21.707 – to latest version (2.10.878)
But it worked for me:
I think it must have something to do with the Cypress programmer and vectors for the PSOC6 devices not in the previous KitProg 3 firmware version.
– Since I looked with a logic analyzer and I could see the handshake happening even when it was not working.
Update your Kitpro3 programmer to the newest firmware rev and I think that will fix your issue.
BTW: I was using ModusToolbox and the Cypress programmer –
Hope that helps
-Mike
Hi @David_Zhang ,
From the logs, I see that you are programming using ModusToolbox. Can you please confirm the same?
Did you try programming a standard PSoC 6 Dev Kit? Were you able to successfully program in this case?
Also, can you please let me know the steps that you followed in creating a custom BSP?
Rakshith M B
Hope that helps
-Mike
