caRa_3762551
First like given
I have used the timer-counter block, but I have not found a way to measure the compilation time of the program
NoriTan
10 sign-ins First question asked 5 sign-ins
Which do you want to measure the COMPILATION time or RUN time?
If you want to measure the RUN time with the TCPWM block, please use following API to read the counter value.  The RUN time will be calculated as the difference between two counter values when a process begins and ends..
/* Scenario: there is a need to get the current counter value of
  * the first (index = 0) counter of the TCPWM0 block
  #define MY_TCPWM_CNT_NUM (0UL)
  uint32_t count = Cy_TCPWM_Counter_GetCounter(TCPWM0, MY_TCPWM_CNT_NUM);
NoriTan
caRa_3762551
First like given
Hi, I want to know the compilation time.
